Автомагнитолы на Android
Сообщение Сэнсэй » Сб ноя 05, 2011 12:56:22
В соседней теме уже вскользь пролетало про существование автомагнитолы с ОС Android, но, думаю, это событие достойно отдельной темы. Тем более, что буквально на днях вышла новая версия с процессором 1ГГц и Android 2.3.
Итак, чудо-дивайс в виде планшето-магнитолы Winmark DM7033:
Различия с предыдущей версией 7022:
CPU Type
Telechips 8803, 1.0 GHz A8 1G (dominant frequency).
CPU Speed
open VG 1.1/open GL ES 1.1&2.0, 20m Polygon@320MHz.
RAM
512MB DDR3
ROM FLASH
4GB
External 3G
external USB dongle; CDMA, WCDMA, TDCDAM.
System
Google Android 2.3 OS
Game
Built-in SD accelerated, perfectly support 3D game, can download many kinds of games and chatting softwares, such as skype, msn etc. Any chatting softwares can call, chat and video.
Battery
3600mA / 3.7V Li-battery, built in battery, the battery Volume is as 3600mAH, and can last 6~8 hours.
MID work temperature
Ten degrees centigrade below zero ~ fifty degrees centigrade normally.
MID storage temperature
Fifteen degrees centigrade below zero ~ seventy degree centigrade.
Полные данные:
Type Item Descriptions
Functions & Hardware Spec. CPU Telechips 8803 A8 1GHz
RAM DDR 3 512MB
ROM FLASH 4GB
LCD 800*480 HD Screen
Extended memory card Up to 32GB SD/TF card
WiFi Bulit-in High performance, low power consumption,WiFi:802.11b/g.
G-SENSOR 3 axis acceleration sensor and 3D IC hardware acceleration, could realize dynamic 3D game and 3D interface.
3G External USB dongle,Support external WCDMA function
CAMERA Support 30W-500W camera
Speaker Internal 8Ω/1W loudspeaker*2
Micphone High sensitivity input, right&left channel
Slot OTG Directly play HD movie in Harddisk,digital camera, mobile phone,U Disk and Card reader; transfer data freely,connect with Printer and other OTG functions
HDMI HDMI; Standard, mini port, Support DMI1.3; Support screen output
USB USB2.0 High speed
HOST HOST1.1, could connect with mouse,keyboard, U disk and other peripheral equipment
Charge Small charger slot,DC9V input
Earphone/Vedio 3.5mm Earphone + CVBS output
OS System Google Android 2.3
GPS GPS navigation Google Android map, could download from internet
Panel Detachable HD 800*480 pixel screen, detachable panel
Display Display 7 inch 800*480 HD screen.
Lanague Simple Chinese,Traditional Chinese,Englsih,French,German,Italian,Japaness,Korean,Russian,Spanish,Polish,Czech and more customer-made lanagues
Internet Explorer Opera,UCWeb,SkyFile,Dolphin and more Exploer for your selection
Online Entertainment Online vedio,TV, movie,music, radio,video chat
Office software WORD,EXCEL,POWERPOINT,PDF,TXT
Game Built-in SD accelerated, perfectly support 3D game
Expansion card Could download more than 20,000 excellent software via Android E-marktet
Audio Format MP3.WMA.MP2.OGG.AAC.M4A.MA4.FLAC.APE.3GP.WAV etc. Could play via song list
Record Format:MP3.WMA
Other LRC synchronized display; ID3 search; Search by files;Album picture;User-defined audio effect
Audio IC Top Global Cirrus IC,independent audio decoding
SNR Noise rations: >=90dB
Vedio Format Support AVI(H.264.DIVX.DIVX.XVID). rm.rmvb. MKV(H.264.DIVX.DIVX.XVID).WMV.MOV.MP4(.H.264.MPEG.DIVX.XVID).DAT(VCD format).VOB(DVD format).PMP.MPEG..MPG.. FLV(H.263.H.264).ASF .TS. TP.3GP.MPG ect, >=30 formats, playing internet vedio directly(while downloading)
Play Up to1920X1080 pixels. 30Mb. Fluent play without light spot
Vedio output HDMI 720P to1080P. full HD output and common vedio output(AV)
Additional Textbook Could change font. Font color. Backgroud color.bookmark. Reading E-book while listening music
Photo View Support JPS.BMP.PNG.GIF etc.. format.play by revolve.powerpoint
Support 4096*4096 pixels
Amplifer Front,back,right,left 4 channels, subwoofer
Others Volume 193*115*14.3mm
Battery 3600mA / 3.7V Li-battery
Work time Movie,music,HDMI output playing time:>3 hours
Weight 335g
Из отзывов установивших предыдущую модель 7022: как ни странно, но всё работает :) GPS-антенны в планшетной части нет, поэтому GPS работает только в пристёгнутом к магнитоле планшете. Все распространённые в СНГ проги-навигаторы работают. При отстёгнутом планшете магнитола работает самостоятельно, крутит диски, флешки, радио. 3G-модем работает только после танцев с бубном, т.к. в зашитых в планшет профилях нет наших операторов. Но повторить танцы можно, всё описано в инете. Из особенностей: на время голосовых подсказок навигатора звук от радио/диска выключается. Анонсировали ёмкостный экран, но в версии 7033 он так и не появился. Возможно, причина в плохом поведении ёмкостных экранов в замёрзших машинах.
При заказе можно указать тип ТВ-тюнера (аналоговый либо DVB-T), одновременно с двумя тюнерами дивайс не работает.
Цена в 400 с небольшим у.е. на ибэе заставляет задуматься...
Re: Автомагнитолы на Android
Сообщение bykovdima » Сб ноя 05, 2011 13:52:25
у меня вот слюнки текут на подобный аппарат :), но для себя не вижу смысла менять свой Witson на Winmark, он исправно справляется с поставленными перед ним задачами.
но тем не менее кое-что меня пугает в этом аппарате - это отстегивающийся планшет, какого-то надежного крепления не видно, т.е. держится наверно на разъеме, а если учесть что машину всегда трясет на дороге, то насколько долговечным будет такое соединение...
Сэнсэй писал(а):Цена в 400 с небольшим у.е. на ибэе заставляет задуматься...
очень интересная цена, Witson + камера заднего вида + доставка мне обошлись в примерно те же деньги
Сообщение Сэнсэй » Сб ноя 05, 2011 13:59:00
Планшет застёгивается в магнитолу на пластиковую застёжку.
Вот нашёл мини-обзор от пользователя, правда, предыдущей версии 7022. По идее, с новым процом оно пошустрее, чем написано нижe:
Купил себе такую магнитолу. До неё стояла родная японская с тв, но соответственно у нас её заюзать неудалось, да и навигации не сыскать.
Вообщем юзаю неделю и вот что могу сказать.
Решение отличное, как уже в других темах обсуждали, можно и в руках носить и в машине использовать.
сначала о достоинствах:
ГОЛОВА:
1. На лицевой части есть разъём для микросд. (после нескольких эксперементов выяснилось что флешка в голове читает только музыку, видео не воспроизводит.)
2. Сама голова выполнена в стиле "простомафон" по этому не стоит переживать о том, что воры за ней полезут.
3. Мощность звука достаточная для простого прослушивания музыки.
4. Линейные выходы и входы (камера, видео in-out, subwf, все каналы звука, aux, usb)
5. Громкая связь работает хорошо (микрофон- отлично, громкость речи- нужно прибавлять до 15-18 едениц что бы слышать собеседника.
Недостатки, незначительные. (незнаю недостатки это или нет, но я обязан их указать)
1. Графический эквалайзер - муляж (столбики прыгают сами по себе, не зависимо от музыки.)
2. Места для жёлтой наклейти другого не нашли.
Планшет:
Достоинства:
1. Андроид (любой софт , навигация, утилиты, игры и тд)
2. Удобная регулировка подсветки (ночью актуально)
3. Возможность выключать дисплей (только в режиме car)
4. GPS ловит 12 спутников из 12-ти
5. Проигрывает с микросд все форматы видео и аудио.
6. Возможность снимать панель и оставаться в работе (интернет, калькулятор, файлы, кино, книги, плеер)
7. Соединение с интернетом через wifi карты, пробки, покер)) (я поключаюсь к интернету через телефон, через точку доступа mobile AP. интернет- мегафон анлим)
8. Нужные разъёмы.
Недостатки
1. Самый жырный недостаток это производительность.
скорость операционной системы на очень низком уровне. Если отключить все службы, которые не нужны повседневно, то скорость существенно поднимается.
Сразу обратил внимание на skype и ещё некоторые приложения которые грузятся при старте, они ненужны, но их можно отключить как службы.
При включении анимированных обоев лаги возрастают, что ещё раз говорит о том, что процессор всегда на пределе. Отключение ненужного софта и установка простых обоев поднимает производительность. Ну может дело в самой оси, а не в проце.
В игре ангри бёрдс нет надписей, там где должны быть надписи просто белые квадратики. Язык менял, не помогло.
2. GPS встроен в панель, но антена похоже только в голове, снял нанель и спутников стало 0. (значит в лес поход отменяется)
3. GPS работает точно, но скорость почему-то показывает х2. То есть, если мы едем 100, то на навигации или на софте gps test получаем 200! (можно фейки снимать на ютуб). Это явно проблемы софта, так как если запустить софтинку Одиссей спидометр и Навител одновременно, то в навителе показывает нормальную скорость. (выяснилось случайно)
4. При нажатии кнопки MUTE, экран не откликается на нажатия.
5. Зарядка на 2 часа максимум.
6. Большой вес.
7. Приложения с Андроид маркета савит не все. (незнаю, что я делаю не так)
8. Иногда повисает в выключеном состоянии экрана, помогает ресет. Было пару раз. (респект, что не сбрасывает настройки после ресета)
TV - не проверял, нет тв антены.
Рекомендации:
При подключении питания, соеденяйте жёлтый и красный провод вместе, так как при старте авто, сигнал на красном пропадает на время работы стартера и в этот момент Андроид думает, что вы выключили магнитолу и начинает вырубать ОС, сначала он её вырубает, а потом сразу врубает, это занимает пару минут, очень неудобно. А при соедении красного и жёлтого, при работе стартера питание не рвётся.
Для работы DVD находу нужно розовый провод потключить к любому минусу. Мало ли, дети будут смотреть.
Вердикт, не смотря на некоторые недостатки, считаю эту магнитолу отличным решением. Многие из недостатков на использовании в авто не влияют. Желаю разработчикам поскорее обратить внимание на скорость ОС и тогда она станет гораздо популярнее, и китай не будут по прежнему глумить. Кстати говоря в поддержке работают адекватные люди, готовые помогать и принимать замечания, на писма в почте отвечают быстро. И ещё, в коробке с магнитолой были бумаги (инструкции и тд) так вот там ни одного слова по китайски, всё на русском в цветных картинках на хорошей полиграфии.
Я доволен, мечта встроить CARPC осуществилась самым неожиданным образом.
Скоро сниму видео обзор, выложу. Раскажу про + и -.
Вс ноя 04, 2007 21:45:50
Cash on hand: 14.76
Благодарил (а): 74 раз.
Сообщение Станислав » Сб ноя 05, 2011 14:14:11
Дааа...За ними будущеее.Я в принципе и Caska доволен,но этот тоже ничего(да за такие деньги) =D>
Сообщение flex » Пт сен 14, 2012 18:07:07
Спецы из Sonic Electronics решили проинсталить Google Nexus 7 в машину... по-моему, у них неплохо получилось.
Пт мар 18, 2011 21:03:02
Cash on hand: 226.27
Сообщение Shadow » Пт сен 14, 2012 18:18:47
Стандартная 2DIN на Android сугубо для авто, без всяких излишеств вроде съемных планшетов и т.п... Свежая...
http://www.autocentre.ua/news/Service/47869.html
Сообщение flex » Пт сен 14, 2012 18:40:30
Shadow писал(а):Стандартная 2DIN на Android сугубо для авто, без всяких излишеств вроде съемных планшетов и т.п... Свежая...
Таких уже полно в инете... только все они обычно на версии 2.х андроида, которую трудно назвать "свежей". А фишка планшетного варианта в том, что он сьемный и через какое-то время относительно недорогое "железо" (на примере Нексус 7) можно легко обновить.
